Ana içeriğe geç
Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement, Volume, Camera, & Power Buttons: adım 1, 1 resimden 1.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 4, 1 resimden 1.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the desired button by pushing inward with the spudger or disconnecting the rubber pin connections.
Sonuç
Ricardo Zuloaga
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 276
