Ana içeriğe geç
Samsung Galaxy R Front Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Front Facing Camera Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy R Front Facing Camera Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy R Front Facing Camera Replacement, Battery: adım 2, 3 resimden 3.
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: adım 3, 2 resimden 1. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: adım 3, 2 resimden 2.
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 1. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 2. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 3.
    • The front facing camera is located in the top right corner of the back of the phone.
    • To remove the camera, gently pull until it detaches from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keon Horahan
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G3
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 408
