Ana içeriğe geç
Samsung Galaxy R Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy R Motherboard Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy R Motherboard Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy R Motherboard Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Motherboard Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy R Motherboard Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy R Motherboard Replacement, Battery: adım 2, 3 resimden 3.
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Motherboard Replacement, Screws: adım 3, 2 resimden 1. Samsung Galaxy R Motherboard Replacement, Screws: adım 3, 2 resimden 2.
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Motherboard Replacement, Bottom Panel: adım 4, 3 resimden 1. Samsung Galaxy R Motherboard Replacement, Bottom Panel: adım 4, 3 resimden 2. Samsung Galaxy R Motherboard Replacement, Bottom Panel: adım 4, 3 resimden 3.
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Motherboard Replacement, Top Panel: adım 5, 3 resimden 1. Samsung Galaxy R Motherboard Replacement, Top Panel: adım 5, 3 resimden 2. Samsung Galaxy R Motherboard Replacement, Top Panel: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to grasp the circular silver metal piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Motherboard Replacement, Remove Motherboard: adım 6, 1 resimden 1.
    • If you want to replace motherboard, gently pull motherboard from the back of the phone.
    • The parts indicated in red color are attached by adhesive to the back of the phone, so more force will be necessary to remove these areas.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Keon Horahan
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G3
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 25
Son 30 gün: 76
Her zaman: 1,881
