Ana içeriğe geç
Samsung Galaxy R Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Rear Facing Camera Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy R Rear Facing Camera Replacement, Battery: adım 2, 3 resimden 3.
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Rear Facing Camera Replacement, Remove screws: adım 3, 2 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Remove screws: adım 3, 2 resimden 2.
    • With the Phillips head screwdriver, remove all seven 4.0mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: adım 4, 3 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: adım 4, 3 resimden 2. Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: adım 4, 3 resimden 3.
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: adım 5, 3 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: adım 5, 3 resimden 2. Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to grasp the vibrator firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: adım 6, 3 resimden 1. Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: adım 6, 3 resimden 2. Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: adım 6, 3 resimden 3.
    • The rear facing camera is located near the top center on the underside of the motherboard.
    • To remove the camera, flip the orange clip circled in red and pull the camera from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keon Horahan
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G3
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 344
