Ana içeriğe geç
Samsung Galaxy Rush Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Rush Display Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy Rush Display Replacement, Rear Case: adım 1, 2 resimden 2.
    • Looking at the back of your phone, use your finger to remove back cover.
  2. Samsung Galaxy Rush Display Replacement: adım 2, 2 resimden 1. Samsung Galaxy Rush Display Replacement: adım 2, 2 resimden 2.
    • Remove the battery.
  3. Samsung Galaxy Rush Display Replacement: adım 3, 1 resimden 1.
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  4. Samsung Galaxy Rush Display Replacement: adım 4, 2 resimden 1. Samsung Galaxy Rush Display Replacement: adım 4, 2 resimden 2.
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  5. Samsung Galaxy Rush Display Replacement, Connectors: adım 5, 2 resimden 1. Samsung Galaxy Rush Display Replacement, Connectors: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
  6. Samsung Galaxy Rush Display Replacement: adım 6, 2 resimden 1. Samsung Galaxy Rush Display Replacement: adım 6, 2 resimden 2.
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
  7. Samsung Galaxy Rush Display Replacement: adım 7, 1 resimden 1.
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  8. Samsung Galaxy Rush Display Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard upwards separating it from your screen.
Sonuç
Kenny Afiadata
34 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G4
3 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
where to get mother board
Braulio P - Yanıt
where to get mother board really cheap
Braulio P - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 783
