Ana içeriğe geç
Samsung Galaxy S Blaze Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy S Blaze Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy S Blaze Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy S Blaze Motherboard Replacement: adım 5, 3 resimden 3.
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: adım 6, 1 resimden 1.
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
Sonuç
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 farklı kişi bu kılavuzu tamamladı.
Rene Bolanos
435 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 877
