Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
Use a flat tool to pry the two plastic cases apart
The latches are very strong, so don't be afraid to use force
Locate the missing button slot
Place in replacement button, and close the plastic housing around it
The button should be fully functional now, repeat past steps to reassemble the phone
Bir Yorum
Please can someone help me with samsung t769 power way on the board ?
