Ana içeriğe geç
Samsung Galaxy S Blaze SD Card Slot Cover Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement, SD Card Slot Cover: adım 1, 1 resimden 1.
    • Make sure the device is powered off and not plugged into a power source.
    • Remove the back plate to reveal the battery.
  2. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 2, 1 resimden 1.
    • Use a spudger or your fingers to remove the battery from the phone.
  3. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 3, 2 resimden 1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
  4. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 4, 1 resimden 1.
    • Use the blue plastic opening tool to gently pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 5, 2 resimden 1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: adım 5, 2 resimden 2.
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
Sonuç
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 farklı kişi bu kılavuzu tamamladı.
Rene Bolanos
435 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 397
