Ana içeriğe geç
Samsung Galaxy S Blaze Volume Rocker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: adım 1, 1 resimden 1.
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 3, 2 resimden 1. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 3, 2 resimden 2.
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 4, 1 resimden 1.
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 5, 2 resimden 1. Samsung Galaxy S Blaze Volume Rocker  Replacement: adım 5, 2 resimden 2.
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
Sonuç
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Bir başkası bu kılavuzu tamamladı.
Jake Best
261 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 386
