Ana içeriğe geç
Samsung Galaxy S II Front Glass/Digitizer Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: adım 1, 2 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: adım 1, 2 resimden 2.
    • We have a Samsung Galaxy S II with broken screen.
  2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 2, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 2, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 2, 3 resimden 3.
    • Remove your battery, the SIM card and the SD card.
    • Remove the 7 screws highlighted in red.
  3. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 3, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 3, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 3, 3 resimden 3.
    • Use a plastic tool to remove the rear housing.
  4. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 4, 2 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 4, 2 resimden 2.
    • The mother board is held by 2x screws. Remove them.
  5. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 5, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 5, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 5, 3 resimden 3.
    • Remove the cables that are highlighted in red, before continuing to the screen.
  6. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 6, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 6, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 6, 3 resimden 3.
    • Release the side buttons. The arrow will point you to where they are.
  7. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 7, 2 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 7, 2 resimden 2.
    • Careful release the motherboard from it's housing.
  8. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 8, 2 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 8, 2 resimden 2.
    • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
    • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • Use a hot air to soften the adhesive enough to remove the glass.
  9. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 9, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 9, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 9, 3 resimden 3.
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
  10. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 10, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 10, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 10, 3 resimden 3.
    • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
  11. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 11, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 11, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 11, 3 resimden 3.
    • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
  12. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 12, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 12, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 12, 3 resimden 3.
    • Clean the frame from the remains of tape.
  13. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 13, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 13, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 13, 3 resimden 3.
    • Test the new spare part before reassembling.
  14. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 14, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 14, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 14, 3 resimden 3.
    • Install the LCD&Digitiser on it's housing.
    • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
  15. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 15, 3 resimden 1. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 15, 3 resimden 2. Samsung Galaxy S II Front Glass/Digitizer Replacement: adım 15, 3 resimden 3.
    • To reassemble your device, follow these instructions in reverse order.
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
ZFix
194.222 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
9Kılavuz Yorumları
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - Yanıt
Yes, removing the glass is very difficult and you must have some experience from before.
ZFix - Yanıt
To moderators: please un-archive this guide: there's no replacement or "updated version of the guide" among the current guides.
yurkennis - Yanıt
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
Frederic Morelli - Yanıt
how much the cost in replacement display with fame.....samsung galaxy s2
Bhola Shrestha - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 98,842
