Giriş
If you have a Samsung GALAXY SII with broken Touchscreen or LCD Display, this manual will guide, how to change them.
This procedure is very hard. You must have good experience to do this !!!
Same steps you can use for replacing Touchscreen&LCD display with frame. This operation is more easy. If you haven't enough experience, I strongly recommend you, to choose this variant.
_______Video manual_______
Neye ihtiyacın var
Videoya Genel Bakış
At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
Use a hot air to soften the adhesive enough to remove the glass.
How can we preheat without damaging the digitizer. Especially if all we need to replace is the front glass only?
Thank you.
I have to fix my daughters SII and I would also like to know how to preheat the glass? There's nothing in the video either - please help?
If you haven't experience don't try this. You can buy complected part - Touch screen+ Display+Frame. I reheat it until is hard to hold it. There isn't problem if you preheat the screen because this is the broken part. You must take care for the frame.
ZFix -
32 farklı kişi bu kılavuzu tamamladı.
9 Yorum
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
how much the cost in replacement display with fame.....samsung galaxy s2
I tried replacing only the glass. I had two Samsung S2 phones:
Phone 1: Samsung Galaxy S2 with broken LCD only
Phone 2: Another Samsung Galaxy S2 with broken glass only
So I tried to swap the glass from phone 1 to phone 2. I heated the glass with a hairdryer for a few minutes. The glue is stronger than other phones, it was hard to get started. I used a tiny flathead screwdriver to lift the corner enough to push a plastic guitar pick under. Use plastic not metal to avoid scratching the glass or LCD. Slowly working the pick around the edge, reheating every 30 seconds, using more picks to keep the glass separate, I got the whole piece of glass off phone 1 intact. I repeated this process with phone 2 and removed the shattered glass, but unfortunately I internally cracked the good LCD while cleaning the screen and edges with some spirits. I would try this again, being more careful not to put pressure on the exposed LCD. I believe this can be completed by any patient and careful amateur like myself. Good Luck!
i have two s2's, im keeping the working digitizer and placing it onto the phone with the broken screen because of my motherboard, this guide is wrong in how it says its really hard and it only takes about ten minutes not 35
I can not open the back of my phone.
Is the A11 that i was sent as a replacement phone 3 days ago..the same as an S11..which i located with directions. These directions state..how to dissemble entire phone! All i need to do is find directions on.. how to take the back panel Off.Sad.
