Ana içeriğe geç
Samsung Galaxy S II Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S II Screen Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Gently remove the back cover starting from the slot given on the right side.
  2. Samsung Galaxy S II Screen Replacement, Remove battery: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the battery from the slot.
    • Carefully place the battery away from some hot object or fire.
  3. Samsung Galaxy S II Screen Replacement, Remove back case screws: adım 3, 1 resimden 1.
    • Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
    • Place the screws carefully in a box.
  4. Samsung Galaxy S II Screen Replacement: adım 4, 3 resimden 1. Samsung Galaxy S II Screen Replacement: adım 4, 3 resimden 2. Samsung Galaxy S II Screen Replacement: adım 4, 3 resimden 3.
    • Gently unlock the snap locks starting from the top left corner and progressing along the perimeter to remove the back case.
    • To unlock the snaps, apply force close to the snap in order to avoid cracking of the plastic cover.
    • Remove the plastic cover carefully and place on the white paper.
  5. Samsung Galaxy S II Screen Replacement: adım 5, 2 resimden 1. Samsung Galaxy S II Screen Replacement: adım 5, 2 resimden 2.
    • Use a screwdriver or another pointed tool to disconnect the screen connector.
    • Lift the cable out of the slot.
    • Gently handle the cable to avoid damage to the cable or the connector.
  6. Samsung Galaxy S II Screen Replacement: adım 6, 2 resimden 1. Samsung Galaxy S II Screen Replacement: adım 6, 2 resimden 2.
    • Remove the connector for the speaker and audio jack carefully.
    • Gently lift the cable to avoid damage to the cable or the connector.
  7. Samsung Galaxy S II Screen Replacement: adım 7, 3 resimden 1. Samsung Galaxy S II Screen Replacement: adım 7, 3 resimden 2. Samsung Galaxy S II Screen Replacement: adım 7, 3 resimden 3.
    • Use a screwdriver to gently lift the speaker which is fixed to the base with double side tape.
    • Gently lift the earpiece using a flat screwdriver.
  8. Samsung Galaxy S II Screen Replacement: adım 8, 3 resimden 1. Samsung Galaxy S II Screen Replacement: adım 8, 3 resimden 2. Samsung Galaxy S II Screen Replacement: adım 8, 3 resimden 3.
    • Unplug the secondary camera connector carefully and lift the cable.
    • Then unplug the connector that receives the input from the screen.
    • Remove the connection for the charging port using a screw driver.
    • Handle carefully to avoid tearing off the cable.
  9. Samsung Galaxy S II Screen Replacement: adım 9, 2 resimden 1. Samsung Galaxy S II Screen Replacement: adım 9, 2 resimden 2.
    • Remove the two 1.6 mm black head screws using the Phillips #00 screwdriver.
  10. Samsung Galaxy S II Screen Replacement: adım 10, 2 resimden 1. Samsung Galaxy S II Screen Replacement: adım 10, 2 resimden 2.
    • Disconnect the antennae from both the ends by removing the connections using flat screwdriver.
    • Carefully pull out the antennae cable from the slot.
  11. Samsung Galaxy S II Screen Replacement: adım 11, 2 resimden 1. Samsung Galaxy S II Screen Replacement: adım 11, 2 resimden 2.
    • Gently peel off the power button fixed with double adhesive tape.
    • Carefully lift the button out of the slot.
    • Try to keep the double side tape on the button and handle the cable carefully to avoid tearing the ribbon.
  12. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: adım 12, 2 resimden 1. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: adım 12, 2 resimden 2.
    • Repeat the same procedure from step 15 to remove the volume up down button.
  13. Samsung Galaxy S II Screen Replacement, Remove main board: adım 13, 2 resimden 1. Samsung Galaxy S II Screen Replacement, Remove main board: adım 13, 2 resimden 2.
    • Now the main board is free. Carefully lift it up and place on the workbench gently.
  14. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: adım 14, 2 resimden 1. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: adım 14, 2 resimden 2.
    • Peel off the ribbon cable connecting the charging port and microphone by hand.
  15. Samsung Galaxy S II Screen Replacement, Unscrew charging module: adım 15, 1 resimden 1.
    • Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
  16. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: adım 16, 3 resimden 1. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: adım 16, 3 resimden 2. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: adım 16, 3 resimden 3.
    • Lift the microphone gently.
    • Lift the board out from the metal casing and place on the workbench.
  17. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: adım 17, 3 resimden 1. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: adım 17, 3 resimden 2. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: adım 17, 3 resimden 3.
    • Finally push the screen out applying force through the screwdriver at the highlighted locations.
    • Take out the screen, clean the remaining double side tape and adhesive.
    • Install the new screen and follow the same steps in reverse order to re assemble the phone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
My Samsung Galaxy s2 is an AT&T phone
Anthony Godoy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 2,266
