Ana içeriğe geç
Giriş
The most common use of the SIM card is for storing contacts and synchronizing with your mobile carrier. This small part is vital to the operation of the phone since it directly affects the ability to receive calls and messages as well as creating interruptions of service.
Aletler
Hiçbir alet belirtilmedi.
Parçalar
Hiçbir parça belirtilmedi.
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. The SIM card is the small white rectangle located in the red rectangle. To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal. To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
Sonuç
Joshua King
1.330 İtibar
9 adet Kılavuz yazıldı
Takım
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 8
Her zaman: 2,175
