Giriş
Use this guide to replace the SIM card.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
41 farklı kişi bu kılavuzu tamamladı.
3 Yorum
i was trying to find the sims card and insted i pulled the slot loose from the phone can it be fixed or replaced
