Ana içeriğe geç
Samsung Galaxy S III microSD Card Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S III microSD Card Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement, Rear Case: adım 1, 2 resimden 2.
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III microSD Card Replacement: adım 2, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 2, 2 resimden 2.
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III microSD Card Replacement: adım 3, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 3, 2 resimden 2.
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III microSD Card Replacement: adım 4, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 4, 2 resimden 2.
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III microSD Card Replacement: adım 5, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 5, 2 resimden 2.
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III microSD Card Replacement, Battery: adım 6, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement, Battery: adım 6, 2 resimden 2.
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III microSD Card Replacement: adım 7, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 7, 2 resimden 2.
    • Remove the battery.
  8. Samsung Galaxy S III microSD Card Replacement, microSD Card: adım 8, 3 resimden 1. Samsung Galaxy S III microSD Card Replacement, microSD Card: adım 8, 3 resimden 2. Samsung Galaxy S III microSD Card Replacement, microSD Card: adım 8, 3 resimden 3.
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  9. Samsung Galaxy S III microSD Card Replacement: adım 9, 2 resimden 1. Samsung Galaxy S III microSD Card Replacement: adım 9, 2 resimden 2.
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 34
Her zaman: 15,830
