Ana içeriğe geç
Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 2, 2 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 5, 3 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 5, 3 resimden 2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 5, 3 resimden 3.
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 6, 2 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 6, 2 resimden 2.
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
  8. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: adım 8, 2 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: adım 8, 2 resimden 2.
    • Locate the three snap on ribbon cable connectors on the motherboard.
    • Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
  9. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 9, 1 resimden 1.
    • With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
    • Take care when moving the motherboard not to allow any of the ribbon cables to be pulled on.
    • The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
  10. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
    • Take care to not damage the button itself or its connecting ribbon cable when detaching the button.
    • The glue which holds the button in place will remain tacky allowing the button to be replaced without the need for additional glue.
  11. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 11, 2 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 11, 2 resimden 2.
    • With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
    • Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
    • The Headphone Jack is held in place with adhesive that will remain tacky after being removed, allowing it to be replace without the need for additional glue.
  12. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 12, 2 resimden 1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: adım 12, 2 resimden 2.
    • Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
    • The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
    • With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Catlin
79 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G37
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Nice Idea Good for beginners. :)
Spy Mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 3,099
