Ana içeriğe geç
Samsung Galaxy S Vibrant LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Vibrant LCD Screen Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy S Vibrant LCD Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 2, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant LCD Screen Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 5, 3 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 5, 3 resimden 2. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 5, 3 resimden 3.
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 6, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 6, 2 resimden 2.
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant LCD Screen Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 2. Samsung Galaxy S Vibrant LCD Screen Replacement, Unhooking Antenna Cable: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
  8. Samsung Galaxy S Vibrant LCD Screen Replacement, Headphone Jack/Ear Speaker: adım 8, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement, Headphone Jack/Ear Speaker: adım 8, 2 resimden 2.
    • Locate the three snap on ribbon cable connectors on the motherboard.
    • Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
  9. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 9, 1 resimden 1.
    • With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
    • Take care when moving the motherboard not to allow any of the ribbon cables to be pulled on.
    • The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
  10. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 10, 1 resimden 1.
    • Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
    • Take care to not damage the button itself or its connecting ribbon cable when detaching the button.
    • The glue which holds the button in place will remain tacky allowing the button to be replaced without the need for additional glue.
  11. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 11, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 11, 2 resimden 2.
    • With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
    • Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
    • The Headphone Jack is held in place with adhesive that will remain tacky after being removed, allowing it to be replace without the need for additional glue.
  12. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 12, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 12, 2 resimden 2.
    • Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
    • The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
    • With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
  13. Samsung Galaxy S Vibrant LCD Screen Replacement, LCD Screen: adım 13, 1 resimden 1.
    • Use a heat gun or hairdryer to loosen the adhesive that secures the touch panel to the screen assembly.
    • Wear heat resistant gloves when removing the screen.
  14. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 14, 2 resimden 1. Samsung Galaxy S Vibrant LCD Screen Replacement: adım 14, 2 resimden 2.
    • Use a plastic opening tool or guitar pick to carefully remove the touch panel from the screen assembly.
    • Start from the top edge and carefully wedge your tool between the screen and frame.
    • Carefully slide your tool along the framework.
    • If the screen is cracked, cover the face in masking tape to prevent broken glass from chipping off.
    • You may need to reheat the adhesive as you work around the edges.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Taylor Catlin
82 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G37
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 16,242
