Giriş
Is your phone not playing music correctly or at all? This guide will help your fix this problem by replacing the media speaker in your phone.
Neye ihtiyacın var
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Locate the seven screws on the plastic casing.
Using the Phillips #00 Screwdriver, remove all seven screws.
Be careful not to lose any of these small screws.
Bir başkası bu kılavuzu tamamladı.
