Ana içeriğe geç
Samsung Galaxy S Vibrant Loud Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 2, 2 resimden 1. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Loud Speaker Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 5, 3 resimden 1. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 5, 3 resimden 2. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 5, 3 resimden 3.
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 6, 2 resimden 1. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 6, 2 resimden 2.
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Loud Speaker Replacement, Loud Speaker: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Locate the seven screws on the plastic casing.
    • Using the Phillips #00 Screwdriver, remove all seven screws.
    • Be careful not to lose any of these small screws.
  8. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 8, 1 resimden 1.
    • Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
    • Be careful not to break any of the plastic snaps.
  9. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 9, 1 resimden 1.
    • After all the plastics snaps have been released, the black plastic casing will come off easily.
    • Locate the speaker.
  10. Samsung Galaxy S Vibrant Loud Speaker Replacement: adım 10, 1 resimden 1.
    • Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
    • Remove the speaker by gently pulling it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Catlin
79 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G37
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 3,111
