Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Follow this guide to remove the back cover for replacement, or to access the Galaxy S10+’s internals. This guide works with either the standard glass back, or the ceramic back.
Neye ihtiyacın var
Unplug and power off your phone before you begin.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
Press the edge of an opening tool into the seam between the back cover and the frame.
Slide the opening tool back and forth along the seam a few times.
Heat an iOpener and apply it to the same edge of the phone for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the bottom edge of the phone for two minutes.
Insert an opening pick into the right edge near the bottom right corner.
Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
Leave an opening pick in the seam to prevent the adhesive from re-sealing.
Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
Use tweezers to pull adhesive chunks, an opening tool to scrape bits off, and high concentration (over 90%) isopropyl alcohol to clean residue.
If you are re-using the back cover, be sure to also remove all adhesive residue from the back cover.
26 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Good guide, pretty easy to follow along
si le cambio la tapa trasera a mi s10 plus deja de funcionar bajo el agua?
That’s correct. The phone will not be water resistant.
Eso es correcto. El teléfono no será resistente al agua.
then How can I keep it water-resistant?
Jeet z -
