Ana içeriğe geç
Giriş
Follow this guide to remove the back cover for replacement or to access the Samsung Galaxy S20’s internals.
You'll need replacement adhesive in order to complete this repair.
  1. Unplug and power off your phone before you begin.
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible. If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  3. Slide the pick back and forth along the bottom edge to slice through the adhesive. Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel. Leave your opening pick in the seam to prevent the adhesive from resealing.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Apply a heated iOpener to the left edge of the back cover for two minutes.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Apply a suction cup to the back of the phone, as close to the center of the left edge as possible. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame. Insert the point of an opening pick into the gap.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive. Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Slide the pick all along the left edge of the phone to separate the back cover's adhesive. Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking. Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  8. Apply a heated iOpener to the right edge of the back cover for two minutes.
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Apply a suction cup to the back of the phone, as close to the center of the right edge as possible. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame. Insert the point of an opening pick into the gap.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Slide the pick all along the right edge of the phone to separate the back cover's adhesive. Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing. As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Apply a heated iOpener to the top edge of the back cover for two minutes.
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover. Gradually slide the pick from the right edge of the device around the top right corner. Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Lift the back cover slowly. Use opening picks to slice any remaining adhesive. Remove the back cover.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to replace the back cover perimeter adhesive before resealing your device.
  14. Apply a heated iOpener to the back cover, over the camera bump for two minutes.
    • Apply a heated iOpener to the back cover, over the camera bump for two minutes.
  15. Insert an opening pick underneath the corner of the microphone board and wiggle the pick from side to side while sliding it in further. Tilt the pick to pry up the board and separate the microphone adhesive. Tilt the pick to pry up the board and separate the microphone adhesive.
    • Insert an opening pick underneath the corner of the microphone board and wiggle the pick from side to side while sliding it in further.
    • Tilt the pick to pry up the board and separate the microphone adhesive.
  16. Use a pair of tweezers remove the microphone from the back cover.
    • Use a pair of tweezers remove the microphone from the back cover.
    • Transfer the microphone to the new back cover.
    • It is possible to reuse the microphone adhesive when installing a replacement back cover, but if you need to replace the adhesive, you can do so with a pre-cut adhesive sheet.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tarun Thiruma
25.326 İtibar
133 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 55
Son 30 gün: 178
Her zaman: 3,203
