Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Samsung Galaxy S20 Back Cover Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S20 Back Cover Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S20 Back Cover Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  3. Samsung Galaxy S20 Back Cover Replacement: adım 3, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement: adım 3, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement: adım 3, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Samsung Galaxy S20 Back Cover Replacement, Heat the left edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Samsung Galaxy S20 Back Cover Replacement, Separate the left edge adhesive: adım 5, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Separate the left edge adhesive: adım 5, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement, Separate the left edge adhesive: adım 5, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Samsung Galaxy S20 Back Cover Replacement: adım 6, 2 resimden 1. Samsung Galaxy S20 Back Cover Replacement: adım 6, 2 resimden 2.
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Samsung Galaxy S20 Back Cover Replacement: adım 7, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement: adım 7, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement: adım 7, 3 resimden 3.
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S20 Back Cover Replacement, Heat the right edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S20 Back Cover Replacement, Separate the right edge adhesive: adım 9, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Separate the right edge adhesive: adım 9, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement, Separate the right edge adhesive: adım 9, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Samsung Galaxy S20 Back Cover Replacement: adım 10, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement: adım 10, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement: adım 10, 3 resimden 3.
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Samsung Galaxy S20 Back Cover Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S20 Back Cover Replacement, Separate the top edge adhesive: adım 12, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Separate the top edge adhesive: adım 12, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement, Separate the top edge adhesive: adım 12, 3 resimden 3.
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Samsung Galaxy S20 Back Cover Replacement, Remove the back cover: adım 13, 2 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Remove the back cover: adım 13, 2 resimden 2.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  14. Samsung Galaxy S20 Back Cover Replacement, Heat the microphone adhesive: adım 14, 1 resimden 1.
    • Apply a heated iOpener to the back cover, over the camera bump for two minutes.
  15. Samsung Galaxy S20 Back Cover Replacement, Release the microphone adhesive: adım 15, 3 resimden 1. Samsung Galaxy S20 Back Cover Replacement, Release the microphone adhesive: adım 15, 3 resimden 2. Samsung Galaxy S20 Back Cover Replacement, Release the microphone adhesive: adım 15, 3 resimden 3.
    • Insert an opening pick underneath the corner of the microphone board and wiggle the pick from side to side while sliding it in further.
    • Tilt the pick to pry up the board and separate the microphone adhesive.
  16. Samsung Galaxy S20 Back Cover Replacement, Remove the microphone: adım 16, 1 resimden 1.
    • Use a pair of tweezers remove the microphone from the back cover.
    • Transfer the microphone to the new back cover.
    • It is possible to reuse the microphone adhesive when installing a replacement back cover, but if you need to replace the adhesive, you can do so with a pre-cut adhesive sheet.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Tarun Thiruma
35.301 İtibar
134 adet Kılavuz yazıldı
3 Yorum
Cool, great advice
LIGE SIZEMORE - Yanıt
Did not work at all for me. Tried the iOpener many times and a hair dryer plus the suction cup but no luck. In the end I used an Exacto knife to just begin to gently break the glass cover in one spot, inserting no further than the glue edge and then twisting, and cracked the whole thing which thereafter I just peeled off in one minute and cut the adhesive as I went, since it was going to be thrown away when replaced with the new one. Perfect and quick.
liburt - Yanıt
Was easy for me because the backside was coming off anyways. (used desinfectant too often on my hands + phone).
I think the hyperlinks at the end are not right: they both lead to the same guide using pre cut tape.
Rolloblonsko - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 103
Son 30 gün: 525
Her zaman: 25,185
