Giriş
This guide shows how to remove and replace the battery for the Samsung Galaxy S20 Plus.
The battery is held in place with strong adhesive. High concentration (over 90%) isopropyl alcohol is necessary to loosen and release this adhesive.
If your battery is swollen, take appropriate precautions and do not heat your phone.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You'll need replacement adhesive in order to complete this repair.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
Use a spudger to pry up and disconnect the battery connector.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
Remove the loudspeaker and lower midframe.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
Gently peel up and remove the main and auxiliary flex cables.
Pry up and disconnect the left 5G antenna cable from the motherboard.
Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
Apply high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the edges of the battery.
Tilt the device as you apply the alcohol help it penetrate the adhesive underneath the battery.
After you apply the alcohol, continue tilting the phone in all directions for two to three minutes to help the alcohol penetrate further.
Apply a suction handle to the center of the battery.
Brace the top and bottom of the device against your work surface with one hand and firmly pull up on the suction handle with the other.
When the battery begins to lift from the device, proceed to the next step.
Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
Remove the battery.
Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
After completing this guide, calibrate your newly-installed battery.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Do you need new adhesive to glue the front and back of the phone itself back together after replacing the battery?
