Ana içeriğe geç
Samsung Galaxy S21 Rear Camera Replacement
  1. Samsung Galaxy S21 Rear Camera Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  2. Samsung Galaxy S21 Rear Camera Replacement, Separate the bottom adhesive: adım 2, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the bottom adhesive: adım 2, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the bottom adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  3. Samsung Galaxy S21 Rear Camera Replacement, Slice the bottom adhesive: adım 3, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Slice the bottom adhesive: adım 3, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Slice the bottom adhesive: adım 3, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Rear Camera Replacement, Heat the left edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  5. Samsung Galaxy S21 Rear Camera Replacement, Separate the left adhesive: adım 5, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the left adhesive: adım 5, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the left adhesive: adım 5, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  6. Samsung Galaxy S21 Rear Camera Replacement: adım 6, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement: adım 6, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement: adım 6, 3 resimden 3.
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  7. Samsung Galaxy S21 Rear Camera Replacement, Heat the right edge: adım 7, 1 resimden 1.
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Samsung Galaxy S21 Rear Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  9. Samsung Galaxy S21 Rear Camera Replacement: adım 9, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement: adım 9, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement: adım 9, 3 resimden 3.
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  10. Samsung Galaxy S21 Rear Camera Replacement, Separate the corner adhesive: adım 10, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the corner adhesive: adım 10, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the corner adhesive: adım 10, 3 resimden 3.
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  11. Samsung Galaxy S21 Rear Camera Replacement, Reposition the opening picks: adım 11, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Reposition the opening picks: adım 11, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Reposition the opening picks: adım 11, 3 resimden 3.
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  12. Samsung Galaxy S21 Rear Camera Replacement, Heat the camera shell: adım 12, 1 resimden 1.
    • Heat an iOpener and apply it to the camera shell for two minutes.
  13. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 3.
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  14. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 3.
    • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
    • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
    • Be careful with this method, as you risk cracking the plastic back cover.
  15. Samsung Galaxy S21 Rear Camera Replacement: adım 15, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement: adım 15, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement: adım 15, 3 resimden 3.
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Rear Camera Replacement: adım 16, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement: adım 16, 2 resimden 2.
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  17. Samsung Galaxy S21 Rear Camera Replacement: adım 17, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement: adım 17, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement: adım 17, 3 resimden 3.
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  18. Samsung Galaxy S21 Rear Camera Replacement, Remove the back cover: adım 18, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the back cover: adım 18, 2 resimden 2.
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
  19. Samsung Galaxy S21 Rear Camera Replacement, Unclip the motherboard bracket: adım 20, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Unclip the motherboard bracket: adım 20, 2 resimden 2.
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  20. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the battery: adım 21, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 2.
    • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  22. Samsung Galaxy S21 Rear Camera Replacement, Remove the wireless charging coil: adım 23, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the wireless charging coil: adım 23, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Remove the wireless charging coil: adım 23, 3 resimden 3.
    • The wireless charging coil is secured to the phone with light adhesive.
    • Use your fingers to gently peel the wireless charging coil away from the phone.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  23. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the earpiece speaker cable: adım 24, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the earpiece speaker cable: adım 24, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker cable's press connector.
  24. Samsung Galaxy S21 Rear Camera Replacement, Unfasten the earpiece speaker: adım 25, 1 resimden 1.
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the earpiece speaker to the motherboard.
  25. Samsung Galaxy S21 Rear Camera Replacement, Remove the earpiece speaker: adım 26, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the earpiece speaker: adım 26, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Remove the earpiece speaker: adım 26, 3 resimden 3.
    • Insert the point of a spudger into the gap between the right-most edge of the earpiece speaker and the phone.
    • Use the spudger to pry up and release the clips holding the earpiece speaker in place.
    • Use tweezers, or your fingers, to remove the earpiece speaker.
  26. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the front camera: adım 27, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the front camera: adım 27, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector.
  27. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the right-edge cables: adım 28, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the right-edge cables: adım 28, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the right-edge cables: adım 28, 3 resimden 3.
    • Use a spudger to pry up and disconnect the orange press connector adjacent to the 5G antenna cable's press connector.
    • Repeat for the green 5G antenna cable's press connector.
  28. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the left-edge 5G antenna: adım 29, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the left-edge 5G antenna: adım 29, 2 resimden 2.
    • Use a spudger to pry up and disconnect the 5G antenna cable's press connector.
  29. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the power button cable: adım 30, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the power button cable: adım 30, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the power button cable's press connector.
  30. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the display cable: adım 31, 2 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the display cable: adım 31, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector.
  31. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the interconnect cables: adım 32, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the interconnect cables: adım 32, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Disconnect the interconnect cables: adım 32, 3 resimden 3.
    • Use a spudger to pry up and disconnect the secondary interconnect cable's press connector.
    • Repeat for the main interconnect cable's press connector.
  32. Samsung Galaxy S21 Rear Camera Replacement, Reposition the left-edge cables: adım 33, 1 resimden 1.
    • Use a spudger, or your fingers, to bend the power button cable away from the phone.
    • Repeat for the left-edge 5G antenna cable.
    • Avoid folding or sharply bending the cables while repositioning them; doing so could tear the cables.
  33. Samsung Galaxy S21 Rear Camera Replacement, Reposition the right-edge cables: adım 34, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Reposition the right-edge cables: adım 34, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Reposition the right-edge cables: adım 34, 3 resimden 3.
    • Use tweezers, or your fingers, to bend the orange 5G antenna cable away from the phone.
    • Repeat for the green 5G antenna cable.
  34. Samsung Galaxy S21 Rear Camera Replacement, Unfasten the motherboard/camera bracket: adım 35, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 4 mm screw securing the camera bracket and the motherboard to the frame.
  35. Samsung Galaxy S21 Rear Camera Replacement, Remove the motherboard assembly: adım 36, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the motherboard assembly: adım 36, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Remove the motherboard assembly: adım 36, 3 resimden 3.
    • Insert a spudger between the bottom-right edge of the motherboard assembly and the frame.
    • Pry up with the spudger to release the clips securing the motherboard assembly.
    • Use your fingers to remove the motherboard assembly.
  36. Samsung Galaxy S21 Rear Camera Replacement, Remove the ultra wide camera: adım 37, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the ultra wide camera: adım 37, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Remove the ultra wide camera: adım 37, 3 resimden 3.
    • Use the point of spudger to pry up and disconnect the ultra wide camera's press connector from the motherboard.
    • Use tweezers, or your fingers, to remove the ultra wide camera.
  37. Samsung Galaxy S21 Rear Camera Replacement, Remove the wide and telephoto camera: adım 38, 3 resimden 1. Samsung Galaxy S21 Rear Camera Replacement, Remove the wide and telephoto camera: adım 38, 3 resimden 2. Samsung Galaxy S21 Rear Camera Replacement, Remove the wide and telephoto camera: adım 38, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the wide and telephoto camera's press connector from the motherboard.
    • Use tweezers, or your fingers, to remove the wide and telephoto camera.
Sonuç
After you've completed the repair, follow this guide to test your repair.
Bir başkası bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
75.553 İtibar
360 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
141 Üyeler
17.757 adet Kılavuz yazıldı
One Comment
Hello, thank you for this awesome tuto. What about the end part: reassembly the back of the phone ?
Auxence A - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 62
Son 30 gün: 300
Her zaman: 4,397
