Ana içeriğe geç
Samsung Galaxy S21 Ultra Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S21 Ultra Battery Replacement, Heat the back cover: adım 1, 1 resimden 1.
    • Unplug and power off your phone before you begin.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 2, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 2, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Ultra Battery Replacement, Slice the adhesive: adım 3, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Ultra Battery Replacement: adım 4, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement: adım 4, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Ultra Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement: adım 5, 3 resimden 3.
    • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Ultra Battery Replacement: adım 6, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement: adım 6, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement: adım 6, 3 resimden 3.
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Ultra Battery Replacement, Remove the back cover: adım 7, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the back cover: adım 7, 2 resimden 2.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers.
    • Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Ultra Battery Replacement, Slice the adhesive: adım 8, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Slice the adhesive: adım 8, 2 resimden 2.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Ultra Battery Replacement: adım 9, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement: adım 9, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement: adım 9, 3 resimden 3.
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the charging coil: adım 10, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the charging coil: adım 10, 2 resimden 2.
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the NFC antenna: adım 11, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the NFC antenna: adım 11, 2 resimden 2.
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Ultra Battery Replacement, Unfasten the NFC antenna & charging coil assembly screws: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Ultra Battery Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 3.
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the battery cable: adım 14, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the battery cable: adım 14, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Ultra Battery Replacement, Unfasten the loudspeaker assembly screws: adım 15, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
  16. Samsung Galaxy S21 Ultra Battery Replacement, Pry up the loudspeaker assembly: adım 16, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Pry up the loudspeaker assembly: adım 16, 2 resimden 2.
    • Insert a spudger into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly by tilting it downwards.
  17. Samsung Galaxy S21 Ultra Battery Replacement, Remove the loudspeaker assembly: adım 17, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the loudspeaker assembly: adım 17, 2 resimden 2.
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the display flex cable: adım 18, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the display flex cable: adım 18, 2 resimden 2.
    • If you're not planning to remove the motherboard or to replace the battery, you can skip this step and continue with the next one.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  19. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 3.
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  20. Samsung Galaxy S21 Ultra Battery Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 3.
    • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
  21. Samsung Galaxy S21 Ultra Battery Replacement, Remove the main flex cable: adım 21, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the main flex cable: adım 21, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Remove the main flex cable: adım 21, 3 resimden 3.
    • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
  22. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the power button flex cable: adım 22, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the power button flex cable: adım 22, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Disconnect the power button flex cable: adım 22, 3 resimden 3.
    • Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
    • Use your spudger to carefully bend the flex cable to the side to avoid damaging it during the battery removal.
  23. Samsung Galaxy S21 Ultra Battery Replacement, Free the battery: adım 23, 2 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Free the battery: adım 23, 2 resimden 2.
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Fold the display flex cable towards the charging port to get free access to the battery.
    • You might want to use a small piece of tape to temporarily stick the cable onto your working surface to avoid accidentally damaging it during the battery removal.
  24. Samsung Galaxy S21 Ultra Battery Replacement, Apply adhesive remover: adım 24, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Apply adhesive remover: adım 24, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Apply adhesive remover: adım 24, 3 resimden 3.
    • The battery adhesive of the Samsung Galaxy S21 Ultra is very strong. If you can't manage to remove the battery by only using high isopropyl alcohol (over 90%) you can try a combination with heat. In this case prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath the battery.
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the left and right edge of the battery.
    • Only apply a few drops and come back again if necessary. The are two cutouts in the midframe of the phone and too much isopropyl alcohol may run to the screen and loosen it.
    • Let the isopropyl alcohol penetrate the battery adhesive for at least two to three minutes.
  25. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 25, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 25, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Insert an opening pick: adım 25, 3 resimden 3.
    • For this step, insert the opening pick into the edge with a wider gap between the midframe and the battery so that you have more space for the opening pick and get a better leverage.
    • Secure a suction handle to the battery, as close to the battery edge as possible.
    • Insert an opening pick into the gap between the edge of the battery and the frame.
    • Twist the opening pick to insert its long edge into the gap.
  26. Samsung Galaxy S21 Ultra Battery Replacement, Pry up the battery: adım 26, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Pry up the battery: adım 26, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Pry up the battery: adım 26, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Satın Al
    • Take care not to puncture or bend the battery during the removal procedure—a punctured or bent battery may leak dangerous chemicals or cause a thermal event. In case you're struggling to pull up the battery apply more isopropyl alcohol and try again.
    • Pull up on the suction handle and tilt the opening pick downwards at the same time to pry up the battery.
    • If you're struggling to pull up the battery with your suction handle you can try to use a heavy-duty suction cup instead.
  27. Samsung Galaxy S21 Ultra Battery Replacement, Remove the battery: adım 27, 3 resimden 1. Samsung Galaxy S21 Ultra Battery Replacement, Remove the battery: adım 27, 3 resimden 2. Samsung Galaxy S21 Ultra Battery Replacement, Remove the battery: adım 27, 3 resimden 3.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
18 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
202.546 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
4 Yorum
is it possible to destroy the screen by heating it up to much?
Danny National (NerdNational) - Yanıt
Hi Danny,
yes it is possible to damage the display if you expose it to too much heat. At the latest when the display discolors under heat, it has become too hot and is damaged. A guideline is about 80 to 90 degrees maximum temperature. If you don't have the possibility to check the temperature exactly, it is recommended to heat the display several times with a lower temperature and to test again and again whether the adhesive can be loosened yet. The device should get just warm enough that you can still touch it.
Dominik Schnabelrauch -
Centigrade for Fahrenheit?
Jeremy Chan -
Sorry for the ambiguity. 80 to 90 degrees centigrade.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 53
Son 7 gün: 373
Son 30 gün: 1,773
Her zaman: 41,323
