Ana içeriğe geç
Samsung Galaxy S4 Active Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S4 Active Midframe Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy S4 Active Midframe Replacement, Rear Case: adım 1, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Midframe Replacement, MicroSD Card: adım 2, 1 resimden 1.
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Midframe Replacement, Battery: adım 3, 1 resimden 1.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Midframe Replacement, SIM Card: adım 4, 1 resimden 1.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Midframe Replacement, Midframe: adım 5, 1 resimden 1.
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Midframe Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
89.901 İtibar
89 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,421
