Ana içeriğe geç
Samsung Galaxy S4 Display Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy S4 Display Assembly Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, Rear Case: adım 1, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Display Assembly Replacement: adım 2, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 2, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Yanıt
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Yanıt
  3. Samsung Galaxy S4 Display Assembly Replacement, MicroSD Card: adım 3, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, MicroSD Card: adım 3, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement, MicroSD Card: adım 3, 3 resimden 3.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Samsung Galaxy S4 Display Assembly Replacement, Battery: adım 4, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, Battery: adım 4, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement, Battery: adım 4, 3 resimden 3.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    it worked for me
    John Donovan - Yanıt
  5. Samsung Galaxy S4 Display Assembly Replacement, SIM Card: adım 5, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, SIM Card: adım 5, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement, SIM Card: adım 5, 3 resimden 3.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Yanıt
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Yanıt
  6. Samsung Galaxy S4 Display Assembly Replacement, Midframe: adım 6, 1 resimden 1.
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    How much it will cost to replace a midframe
    kannan - Yanıt
    How much cost will be on replace a midframe
    Hiren pedhadiya -
    I'm seeing midframes available on Ebay for around $10.
    Alex - Yanıt
    I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
  7. Samsung Galaxy S4 Display Assembly Replacement: adım 7, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 7, 2 resimden 2.
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
    I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
    nicosoranno4gxo - Yanıt
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
    This blue Case Opening tool has a less rigid edge that is kinder to trim than the hard black Spudger shown in later steps. I was glad to have the right tool on hand at this step. Use it as a wedge and slide it along the gap.
    Tom Huber - Yanıt
  8. Samsung Galaxy S4 Display Assembly Replacement: adım 8, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Display Assembly Replacement: adım 9, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 9, 2 resimden 2.
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Display Assembly Replacement: adım 10, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 10, 2 resimden 2.
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
    josephoswald - Yanıt
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
  11. Samsung Galaxy S4 Display Assembly Replacement: adım 11, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 11, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 11, 3 resimden 3.
    • Remove the midframe from the display assembly.
    here i leave them a video i made doing the work
    https://www.youtube.com/watch?v=85pOvI6O...
    enjoy
    Gabriel Barrandeguy - Yanıt
    My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
    Michael Willis - Yanıt
    Just did this on my S4. Instructions were extremely helpful, but I had to remove a screw (step 10.5?) to remove the upper display assembly bracket. Other than that, flawless! Thanks!
    JackieME - Yanıt
    The 3rd image of the 11th step shows that when the midframe is removed, some parts come along with it (at the bottom part of it). What are these parts? should they be removed too and placed in the new midframe? Are they easy to remove?
    Chris - Yanıt
  12. Samsung Galaxy S4 Display Assembly Replacement, Motherboard Assembly: adım 12, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, Motherboard Assembly: adım 12, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement, Motherboard Assembly: adım 12, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
  13. Samsung Galaxy S4 Display Assembly Replacement: adım 13, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 13, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 13, 3 resimden 3.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
    My model had an antenna connection next to the usb board connector in addition to the antenna connection near the display cable connector.
    Drew - Yanıt
    That's point a, on the daughter board (where the USB is located is point b. You must connect it from a to b
    djweijers1997 -
    I could not get the screen connector to fit on with the motherboard assembly in place. I had to remove the motherboard assembly, attach the screen connector, and then carefully replace the motherboard assembly, with the screen connector still attached..
    Tom4G - Yanıt
    Same as Tom4G above. When trying to connect the screen connector, it would not give me that nice clear snap indicating a positive connection. The phone powered up with no screen. So, I disconnected the other connectors again, lifted the motherboard out and connected the screen connector by pinching it with finger and thumb from both sides of the motherboard, this time getting a nice snap when it engaged.
    speedrzr -
  14. Samsung Galaxy S4 Display Assembly Replacement: adım 14, 1 resimden 1.
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    As Sam Lionheart states at the end of this guide, some of these phones have an additional antenna on the opposite side of the phone. Be sure to detach it before removing the motherboard.
    mcr4u2 - Yanıt
  15. Samsung Galaxy S4 Display Assembly Replacement: adım 15, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 15, 2 resimden 2.
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  16. Samsung Galaxy S4 Display Assembly Replacement, Headphone Jack: adım 16, 1 resimden 1.
    • Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
    My assembly had a silver conductive tape shield over the array of components shown in the middle of this photo. I peeled the old one off and attached it in the same location on my new digitizer.
    David - Yanıt
  17. Samsung Galaxy S4 Display Assembly Replacement: adım 17, 1 resimden 1.
    • Remove the headphone jack assembly.
    The headphone jack is surrounded by rubber. It's kind of squeezed in there. You can pry on it to get it out.
    jonathan - Yanıt
    I had a quick question there's a little white rubber circular gasket piece that the headphone jack covers up
    What's that piece called?
    damian lasher - Yanıt
    The small rectangular milky-white silicon gasket appears to be a diffuser for ambient light sensor.  I removed it with a small screwdriver, and replaced it in the same location in my new screen assembly.
    Nicholas Crisp -
    The small rectangular milky-white silicon gasket appears to be a diffuser for an ambient light sensor.  I prised it out of the old assembly and placed it in the new screen assembly.  I also started transferring the components as they were removed from the old screen, so the head-phone jack went straight into the new at this point.  I may regret that later…
    Nicholas Crisp -
    The angle of the picture here makes it appear like the head phone jack needs to be slid out of the top of the phone. This is impossible due to small bits of plastic holding it in at the top. If you're having trouble, the headphone jack is in fact supposed to lift straight up out of the phone.
    sigoshi - Yanıt
    Additionally, there might be a small amount of adhesive holding the headphone jack to the board (there was some in my device). Apply a bit of heat to loosen it up, if needed.
    Mikolaj Banasik - Yanıt
    it is easy to pop off, if you apply pressure to the right point. Using a plastic pair of tweezers or a pry tool, push at the lower right corner and gradually increase the pressure, if you apply enough pressure it will just pop right off.
    Wissmiller Services - Yanıt
  18. Samsung Galaxy S4 Display Assembly Replacement, Display Assembly: adım 18, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement, Display Assembly: adım 18, 2 resimden 2.
    • If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket.
    • Remove the upper display assembly bracket from the display.
    I’ve found that a pretty easy way of popping the bracket off is to slide a thin end of the spudger from the left, then delicately push in - it just popped off easily in my case.
    Be careful with this part! It is very springy. I was gently trying to lift it and it shot across the room!
    NikonErik - Yanıt
  19. Samsung Galaxy S4 Display Assembly Replacement: adım 19, 1 resimden 1.
    • Remove the front-facing camera from the display assembly.
  20. Samsung Galaxy S4 Display Assembly Replacement: adım 20, 1 resimden 1.
    • Remove the earpiece speaker assembly from the display assembly.
  21. Samsung Galaxy S4 Display Assembly Replacement: adım 21, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 21, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 21, 3 resimden 3.
    • Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly.
    • Be careful not to immediately remove the vibrator, as its cable is also adhered to the rear of the display assembly.
    • Use the tip of a spudger to pry the vibrator cable up from the display assembly.
    • Heat works as a great "persuader" here to soften the adhesive. Liberal application of heat from a heat gun will soften the adhesive. If you pry carefully, you can save and re-use the adhesive.
    also you can really feel free to dig the motor out as the housing will be discarded.
    Pavlina G - Yanıt
    I would suggest getting the cable loose first as the vibrator comes out suddenly and you could break off the cable if it is still glued down.
    ken - Yanıt
    bro i cant get it out with a spupger and a i dont have a heat gun/hair dryer any more tips
    Libety Cunty - Yanıt
  22. Samsung Galaxy S4 Display Assembly Replacement: adım 22, 1 resimden 1.
    • Remove the vibrator from the rear of the display assembly.
  23. Samsung Galaxy S4 Display Assembly Replacement: adım 23, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 23, 2 resimden 2.
    • Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post.
    Use a tiny screwdriver to pry up next to the left post of the USB port bracket instead of the spudger and it will pop right off. I tried the spudger but it didn't work for me.
    computeripodrepair - Yanıt
  24. Samsung Galaxy S4 Display Assembly Replacement: adım 24, 1 resimden 1.
    • Remove the USB port bracket from the USB port.
    • The bracket is slightly springy and should pop back into place on the two screw posts during reassembly.
  25. Samsung Galaxy S4 Display Assembly Replacement: adım 25, 2 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 25, 2 resimden 2.
    • Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board
    • Disconnect the antenna connector cable from the USB board.
  26. Samsung Galaxy S4 Display Assembly Replacement: adım 26, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 26, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 26, 3 resimden 3.
    • The USB board is secured to the display assembly with light adhesive.
    • Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place.
    • Go slow and be careful not to bend the board.
    This one was a bit tricky. The board was very tight to the frame so I ended up having to remove the board from the opposite side slowly until I got to the front, then used the tool to remove it.
    mitch - Yanıt
    I also had the most trouble with this part -- it's very well-glued to the assembly, so I used my hair dryer to loosen it somewhat and pried it up with tweezers. This seems to be the part most likely to crack (because it's long and glued down the entire length of the board), so I recommend patience and a little heat to help things along.
    Andrew Richards - Yanıt
    I’ve found that applying the heat loosens up the adhesive, making it easier to remove the board.
    You can either use a heat gun on lowest setting, or a hair dryer, to apply heat to the board area, then start slowly from the left side. Adhesive appears to be applied as a strip of materials, so with enough care, you can keep it in place and for keeping the USB board in place after reassembly.
    Double-sided tape was used in the i9500 version I used. Be very slow. Heat from a hair dryer helped.
    Chris Chaulk - Yanıt
    Working on Verizon SCH-i545, if you’ll follow the instructions, they really do help. The board will bend ever so slightly because your spudger is crafted at an angle by default. The key is to roll it out, and literally keep the spudger as close to the frame as possible. I removed mine with no heat application. I’ll update this once the repair is completed to let you know how the overall process was and what galaxy diags say once the phone is back together. #StrivelinkTech
    Sturgis Baxter - Yanıt
    Repair went well, hardware working as desired. Used a B stock part to replace the screen since it’s a beater phone repair anyway. Board works fine, went back in smoothly with no heat applied.
    Sturgis Baxter -
  27. Samsung Galaxy S4 Display Assembly Replacement: adım 27, 1 resimden 1.
    • Remove the USB board from the display assembly.
  28. Samsung Galaxy S4 Display Assembly Replacement: adım 28, 3 resimden 1. Samsung Galaxy S4 Display Assembly Replacement: adım 28, 3 resimden 2. Samsung Galaxy S4 Display Assembly Replacement: adım 28, 3 resimden 3.
    • Peel up and remove the antenna connector cable from its channel in the rear of the display assembly.
    • Other carrier models may have an additional antenna cable on the opposite side of the phone. Remove this antenna from the display assembly as well.
    • On reassembly, it will be helpful to reinstall the USB board first, and reconnect the antenna connector cable before routing it back into its channel.
    When did the display get replaced? Is the last piece trash and the phone rebuilt on the new one?
    Mark Peterson - Yanıt
    Yep, the component leftover after removing the antenna interconnect cable is the display assembly. The digitizer, LCD and display frame are a glued together unit, replacing the entire assembly is much safer than trying to delaminate the display. The next step would indeed be to rebuild the phone on top of the new display assembly.
    Sam Goldheart -
Sonuç
597 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.980 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.671 adet Kılavuz yazıldı
28Kılavuz Yorumları
HELP! step 28 just ends how do I insert the new one, how do I resemble the parts that used adhesives to stick?
Tom - Yanıt
Nearly all the guides end like this, you just need to work backwards through the steps using the new hardware.
Dave Davidson -
Just work backwards like Nick stated. I usually reverse assemble the parts I take off so I know the order in which I need to put them back in.
Sturgis Baxter -
Just run it along its track. Use a plastic spudger to push it down. Use 3m double sided adhesive tape to re-attach parts that require adhesive.
Fausto Lebron - Yanıt
What is the difference between an AT&T digitizer and a Verizon digitizer? How interchangeable are they?
Martin - Yanıt
I believe the digitizer is the same but if you buy the digitizer with assembly (frame) there is a difference between the models. Here are the model numbers for all the versions. I545 (Verizon) , I337 (AT&T), L720 (Sprint), M919 (T-Mobile), I9500 (International), i9505 (International)
Fausto Lebron -
The "display assembly" I purchased was very simple: glass and LCD and a small board with cable and that's it. It didn't have all this beefy mid frame stuff so I had to reuse my old one. Check to see which part you purchased before going through unnecessary disassembly steps like I did.
Logan Kennedy - Yanıt
This guide was perfect, phone works like new again. Thank you for putting this together.
Brant - Yanıt
When you get to Step 7, it is much safer (for the screen) to begin to separate the mid frame from the seam inside the battery compartment. Place the phone face down on a clean sheet of paper, put your fingernail in the seam and pull it apart with spudger. Much less likely to do any damage to the screen.
Gary McIntosh - Yanıt
Help, i replaced the display assembly, but the touchscreen isn't working. any idea of what i've done wrong? or did maybe damaged something?
lilytjuhh - Yanıt
This just happened to me too, I think I might have pulled the digitizer by mistake or took off the sticker on the back which might have messed up the ribbon cables, did you fix it yet? My touch screen isn't working now also.
justin -
Absolutely 100% perfect. Everything works and I have my Galaxy S4 back. Couldn't be happier!!!
macmcknight - Yanıt
Thanks SOO MUCH! This was awesome. Just pay close attention to the pictures as you go, take your time, and save yourself about $150 vs having a shop do it...
Further advice: DO NOT use anything metal when prying apart the frame in the beginning... The cell phone tool kits are worth it.
jrupertnh - Yanıt
Superb guide, got me there successfully from start to finish ... Thank you
Kevin - Yanıt
I have two phones with the same problem. After reassembly, just before I install the midframe, I check the phone with the sim card and it works perfect. When I install the midframe I get intermittent on one phone and continuous and the other 'sim card not recognized restart the phone'. I get this, as I've said, only when the midframe is re-installed.
JustinTimeToo - Yanıt
Perfect! Great guide, all functions a go.
Don Joseph - Yanıt
I have a Verizon Samsung Galaxy S4, and during disassembly I noticed that it contains two antennas - one in the position as shown in this guide and one on the exact opposite side (colored light red). It too must be disconnected in the same fashion as the antenna in this guide. Removal and installation of both antennas was simple. As the guide suggests, I would recommend installing USB board and motherboard back in place prior to reinstall and routing of antenna wires. Excellent guide. Fixed my broken S4!
coastguard26 - Yanıt
thank you thank you thank you!!!! i didn't have any of the tools but used my thumb nails!
twiskinmcmillan - Yanıt
Easy. Thanks for sharing this tutorial.
Philippe RIPAUX - Yanıt
Hi i want s4 display no wornty i want
pratik wadhwa - Yanıt
This was AWESOME! I was able to fix my phone. It took me about 2 hours as I kept stopping for breaks.
Pavlina G - Yanıt
I did it, and it wasn't too hard.
Here are some tips:
- when removing the midframe, begin from the side with the volume buttons like mentioned here
- the USB board can be bent a bit, it will probably still work fine if it did not crack when you removed it.
- The GT-i9515 also uses the GT-i9505 screen
- make sure that all ribbon cables are really fully attached, apply a bit of pressure
- when reattaching the midframe, make sure to clip in the power button side first, you will have a VERY hard time clipping it on there last. I had to remove the midframe again and start at that side
Schule04 - Yanıt
Great guide, helped me out alot
nev tevi - Yanıt
Thanks - Works well
Rainer Nickel - Yanıt
Good walk through.
Moïse Chadwick - Yanıt
Thanks for the great, easy instructions iFixit!!!
noahthomashall - Yanıt
Great guide, I just did it now for fun, I broke the S4 display in January 2019 and wanted to try to replace the screen. So today I managed it thanks to this guide. The USB board was hard to remove and I bent it like a potato chip, but still works fine. I put the I9505 display part on I9506 and it still works. The plastic mid-frame was super fragile, the places for screws crack easily (even before reassembly) and also the edge broke completely on one place during my re-assembly.
Lukáš Z - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 32
Son 30 gün: 154
Her zaman: 704,225
