Giriş
Use this guide to replace the front-facing camera in your Samsung Galaxy S4.
Parçalar
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
66 farklı kişi bu kılavuzu tamamladı.
10 Yorum
Any instructions for replacing the front speaker? I think I clogged it with glue when replacing the front glass.
Thanks!
Excellent instructions. At step 12, the bracket is fragile and can easily ping off across the room so be careful. Thanks.
