Ana içeriğe geç
Samsung Galaxy S4 Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S4 Midframe Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy S4 Midframe Replacement, Rear Case: adım 1, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Midframe Replacement: adım 2, 3 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 2, 3 resimden 2. Samsung Galaxy S4 Midframe Replacement: adım 2, 3 resimden 3.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: adım 3, 3 resimden 1. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: adım 3, 3 resimden 2. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: adım 3, 3 resimden 3.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Galaxy S4 Midframe Replacement, Battery: adım 4, 3 resimden 1. Samsung Galaxy S4 Midframe Replacement, Battery: adım 4, 3 resimden 2. Samsung Galaxy S4 Midframe Replacement, Battery: adım 4, 3 resimden 3.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Midframe Replacement, SIM Card: adım 5, 3 resimden 1. Samsung Galaxy S4 Midframe Replacement, SIM Card: adım 5, 3 resimden 2. Samsung Galaxy S4 Midframe Replacement, SIM Card: adım 5, 3 resimden 3.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Samsung Galaxy S4 Midframe Replacement, Midframe: adım 6, 1 resimden 1.
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. Samsung Galaxy S4 Midframe Replacement: adım 7, 2 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 7, 2 resimden 2.
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Samsung Galaxy S4 Midframe Replacement: adım 8, 2 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 8, 2 resimden 2.
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Midframe Replacement: adım 9, 2 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 9, 2 resimden 2.
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Midframe Replacement: adım 10, 2 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 10, 2 resimden 2.
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  11. Samsung Galaxy S4 Midframe Replacement: adım 11, 3 resimden 1. Samsung Galaxy S4 Midframe Replacement: adım 11, 3 resimden 2. Samsung Galaxy S4 Midframe Replacement: adım 11, 3 resimden 3.
    • Remove the midframe from the display assembly.
Sonuç
93 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.780 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.581 adet Kılavuz yazıldı
5 Yorum
I cracked the "front facing" bezel on my phone. I thought buying a new mid frame would replace it, but based on these pictures, it looks like it is attached to the the front glass. Is this correct? Is there any way to replace just that front facing bezel?
Marwan - Yanıt
i was wondering the same thing. Can you guys please respond.
Rival Archer -
Yes, the bezel is attached to the front glass. Replacing the glass doesnt cost too much (under 15 eur here) but theres a high chance you will break the lcd digitizer in the process. It needs some skill.
Mark Bernstein -
Hi... Is that the whole body is model GT-I9505 and How much it costs me the whole body?
Priya - Yanıt
Hi.. Is that the whole body is with mirror and how much it costs me??
Priya - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 130,242
