Ana içeriğe geç
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
Neye ihtiyacın var
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: adım 1, 1 resimden 1.
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 2, 1 resimden 1.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 3, 1 resimden 1.
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: adım 4, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: adım 5, 1 resimden 1.
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: adım 6, 1 resimden 1.
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 7, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 7, 2 resimden 2.
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 8, 1 resimden 1.
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 9, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 9, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 10, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 10, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 11, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 11, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 3.
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 13, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 13, 2 resimden 2.
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Richard
34.786 İtibar
11 adet Kılavuz yazıldı
1Rehber Yorum
Thank You so much!
Peter Handless - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 5,954
