Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
Neye ihtiyacın var
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: adım 1, 1 resimden 1.
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 2, 1 resimden 1.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 3, 1 resimden 1.
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: adım 4, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: adım 4, 2 resimden 2.
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: adım 5, 1 resimden 1.
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: adım 6, 1 resimden 1.
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 7, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 7, 2 resimden 2.
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 8, 1 resimden 1.
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 9, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 9, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 10, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 10, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 11, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 11, 2 resimden 2.
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 12, 3 resimden 3.
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 13, 2 resimden 1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: adım 13, 2 resimden 2.
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Richard
29.913 İtibar
11 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.732 adet Kılavuz yazıldı
Bir Yorum
Thank You so much!
Peter Handless - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 5,173
