Ana içeriğe geç
Samsung Galaxy S4 Mini Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: adım 3, 1 resimden 1.
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: adım 4, 2 resimden 1. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: adım 4, 2 resimden 2.
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: adım 5, 1 resimden 1.
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: adım 6, 3 resimden 1. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: adım 6, 3 resimden 2. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: adım 6, 3 resimden 3.
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: adım 7, 2 resimden 1. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: adım 7, 2 resimden 2.
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: adım 8, 1 resimden 1.
    • Insert the new loud speaker
Sonuç
31 farklı kişi bu kılavuzu tamamladı.
Luis Ojeda
989 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G2
5 Üyeler
11 adet Kılavuz yazıldı
3Kılavuz Yorumları
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Yanıt Paylaş
loud & clear Thanks
Maarten Brenninkmeijer - Yanıt Paylaş
perfect. thankyou
rick bailey - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 55
Her zaman: 14,163
