Ana içeriğe geç
Samsung Galaxy S5 Active Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy S5 Active Battery Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
    Great looking guide with well lit pictures and very concise bullet points.
    Rusbell Gonzalez - Yanıt
  2. Samsung Galaxy S5 Active Battery Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy S5 Active Battery Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy S5 Active Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Sonuç
To install the new battery, follow these instructions in reverse order.
11 farklı kişi bu kılavuzu tamamladı.
Nils David Corrales Tovar
3.198 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Hickman Fall 2014 USF Tampa, Team 1-5, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G5
3 Üyeler
Bir Yorum
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 26,488
