Ana içeriğe geç
Samsung Galaxy S5 Mini Daughterboard Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy S5 Mini Daughterboard Replacement, Daughterboard: adım 1, 1 resimden 1.
    • Remove the back cover.
    • Ther is an indent to insert your fingernail and unclip the back panel.
  2. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery. If you have the SIM card and SD card in, remove them as well.
    • Whe re-assembling, make sure the battery contacts line up.
  3. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 3, 2 resimden 2.
    • Open this small cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 4, 3 resimden 3.
    • Heat up the screen and cut the adhesive around the screen. Pry it up and release the LCD screen connector.
    • The connector is located at the top right of the screen, so lift it up or to the left.
  5. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 5, 2 resimden 2.
    • Remove LCD screen.
  6. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 6, 2 resimden 2.
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 7, 2 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 7, 2 resimden 2.
    • Remove mid-plate.
  8. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 8, 3 resimden 3.
    • Remove screw, release USB board flex connector and antenna cable connectors.
  9. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy S5 Mini Daughterboard Replacement: adım 9, 2 resimden 2.
    • Remove the daughterboard and clean the signal cables from assembly. And you can replace the new USB charging board for Samsung Galaxy S5 Mini.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sophia
43.861 İtibar
62 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 5,946
