Ana içeriğe geç
Samsung Galaxy S5 SIM Card Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S5 SIM Card Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy S5 SIM Card Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy S5 SIM Card Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 SIM Card Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy S5 SIM Card Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy S5 SIM Card Replacement, Battery: adım 2, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
    The battery will need to be charged after it is placed in the phone. No one told me that and I bought a battery and thought it was bad. Keep the phone off and insert the charger. You will need to charge it for several hours before you can use the phone.
    Diane Schumacher - Yanıt
  3. Samsung Galaxy S5 SIM Card Replacement, microSD Card: adım 3, 2 resimden 1. Samsung Galaxy S5 SIM Card Replacement, microSD Card: adım 3, 2 resimden 2.
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
    I found removing the SIM/SD card with my fingertip a little difficult – not enough friction. So I used a 'rubber' (in US English it's called a pencil eraser or just simply, an eraser.
    Simple, cheap (zero) and effective! :)
    Cheers.
    John
    johnsg0053 - Yanıt
  4. Samsung Galaxy S5 SIM Card Replacement, SIM Card: adım 4, 1 resimden 1.
    • Repeat the above procedure to remove the SIM card.
    Actually this isn’t as easy as it appears in the photo and instructions, since the SIM card does not have a notch that you can use to pull it out. In my experience I’ve found that the best way to remove the SIM card is by pressing down somewhat hard on the SIM card, and then push-pulling it outward.
    OmniWeb Technical Education - Yanıt
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.783 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
3 Yorum
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - Yanıt
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - Yanıt
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
Misti Weatherwalk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 33
Son 30 gün: 173
Her zaman: 61,334
