Ana içeriğe geç
Samsung Galaxy S5 Sport Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement: adım 2, 3 resimden 3.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: adım 3, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: adım 3, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: adım 3, 3 resimden 3.
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 4, 2 resimden 2.
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: adım 5, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: adım 5, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: adım 5, 3 resimden 3.
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Motherboard Replacement: adım 6, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 6, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement: adım 6, 3 resimden 3.
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
  8. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
  9. Samsung Galaxy S5 Sport Motherboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 9, 2 resimden 2.
    • Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
  10. Samsung Galaxy S5 Sport Motherboard Replacement: adım 10, 2 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the black connector above the wires by pulling straight up with tweezers.
  11. Samsung Galaxy S5 Sport Motherboard Replacement: adım 11, 3 resimden 1. Samsung Galaxy S5 Sport Motherboard Replacement: adım 11, 3 resimden 2. Samsung Galaxy S5 Sport Motherboard Replacement: adım 11, 3 resimden 3.
    • Pull the motherboard out. It should lift easily out of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caroline Janiszewski
531 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 1,641
