Ana içeriğe geç
Samsung Galaxy S5 Sport Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S5 Sport Screen Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy S5 Sport Screen Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy S5 Sport Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Screen Replacement: adım 2, 3 resimden 1. Samsung Galaxy S5 Sport Screen Replacement: adım 2, 3 resimden 2. Samsung Galaxy S5 Sport Screen Replacement: adım 2, 3 resimden 3.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Screen Replacement, Screen: adım 3, 3 resimden 1. Samsung Galaxy S5 Sport Screen Replacement, Screen: adım 3, 3 resimden 2. Samsung Galaxy S5 Sport Screen Replacement, Screen: adım 3, 3 resimden 3.
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Screen Replacement: adım 4, 2 resimden 1. Samsung Galaxy S5 Sport Screen Replacement: adım 4, 2 resimden 2.
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Caroline Janiszewski
531 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 3,979
