Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
For the official iFixit guide to repair your Galaxy S5 nicroSD card, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail. Continue to lift the case, working your way around the perimeter until the entire rear cover is removed. Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
    • Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
    • Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
    Nice work for my phone setting
    BhupSinghBhadu Baf - Yanıt
    Thanks very much A better replace ment
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery. Remove the battery from the phone.
    • Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
    • Remove the battery from the phone.
  4. Gently slide out the SD card using your fingernail or a plastic opening tool. For reassembly, gently slide in the microSD card until it stops. For reassembly, gently slide in the microSD card until it stops.
    • Gently slide out the SD card using your fingernail or a plastic opening tool.
    • For reassembly, gently slide in the microSD card until it stops.
    Thanks for useful setting
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Justin Uchimura
4.416 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-57, Amido Spring 2014 Cal Poly, Team 10-57, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G57
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Actually the battery does not even have to be removed (just unmount in settings first to avoid corruption)
Simply slide the card back until it runs into the battery, then just lift out.
BFeely - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 4,583
