Ana içeriğe geç
Samsung Galaxy S5 microSD Card Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S5 microSD Card Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy S5 microSD Card Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy S5 microSD Card Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 microSD Card Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy S5 microSD Card Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy S5 microSD Card Replacement, Battery: adım 2, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
    The battery will need to be charged after it is placed in the phone. No one told me that and I bought a battery and thought it was bad. Keep the phone off and insert the charger. You will need to charge it for several hours before you can use the phone.
    Diane Schumacher - Yanıt
  3. Samsung Galaxy S5 microSD Card Replacement, microSD Card: adım 3, 2 resimden 1. Samsung Galaxy S5 microSD Card Replacement, microSD Card: adım 3, 2 resimden 2.
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
    I found removing the SIM/SD card with my fingertip a little difficult – not enough friction. So I used a 'rubber' (in US English it's called a pencil eraser or just simply, an eraser.
    Simple, cheap (zero) and effective! :)
    Cheers.
    John
    johnsg0053 - Yanıt
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
My S5 won't read or format a high speed SD card. Any suggestions?
PM Thompson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 15,385
