Giriş
Use this guide to remove the battery from your phone and then replace it with another new battery.
Neye ihtiyacın var
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
After completing this guide, calibrate your newly-installed battery.
42 farklı kişi bu kılavuzu tamamladı.
20 Yorum
thank you for the information on how to dissemble this device Samsung Galaxy S6 Active
You can perform a forced reboot manually. Simultaneously hold down the volume down button and the power button for 10-20 seconds. This will reboot your phone without losing anything.
Looks like the difficult part is the removal of the LCD assembly. What type of adhesive can be used on the LCD screen to glue back on phone?
Never &&^&^$^ answer…
