Ana içeriğe geç
Samsung Galaxy S6 Active Front Camera Replacement
Neye ihtiyacın var
    1. Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: adım 1, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: adım 1, 2 resimden 2.
      • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
      • Pry open the tray to get it out of the socket.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S6 Active Front Camera Replacement: adım 2, 1 resimden 1.
      • Remove the SIM tray with SIM card from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: adım 3, 3 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: adım 3, 3 resimden 2. Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: adım 3, 3 resimden 3.
      • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
      • If using an iOpener, heat it in a microwave for thirty seconds.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S6 Active Front Camera Replacement: adım 4, 1 resimden 1.
      • Attach a suction cup to the lower half of the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy S6 Active Front Camera Replacement: adım 5, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 5, 2 resimden 2.
      • Using the suction cup, pull gently the lower half of the panel.
      • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy S6 Active Front Camera Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Active Front Camera Replacement: adım 6, 3 resimden 3.
      • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
      • Slide the plastic opening tool around the screen, prying the display gently away from the body
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy S6 Active Front Camera Replacement: adım 7, 1 resimden 1.
      • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
      • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy S6 Active Front Camera Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Active Front Camera Replacement: adım 8, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy S6 Active Front Camera Replacement: adım 9, 1 resimden 1.
      • Undo the screen connection with a plastic tool.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Galaxy S6 Active Front Camera Replacement: adım 10, 1 resimden 1.
      • Remove the display assembly (LCD and Digitizer).
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy S6 Active Front Camera Replacement, Battery: adım 11, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement, Battery: adım 11, 2 resimden 2.
      • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S6 Active Front Camera Replacement: adım 12, 1 resimden 1.
      • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
      • You will hear the clips start undoing themselves.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy S6 Active Front Camera Replacement: adım 13, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 13, 2 resimden 2.
      • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
      • The battery will be on the back side of this frame.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy S6 Active Front Camera Replacement: adım 14, 1 resimden 1.
      • Insert a plastic opening tool on the side of the frame and pull out the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy S6 Active Front Camera Replacement: adım 15, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 15, 2 resimden 2.
      • Remove the battery from the frame.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: adım 16, 3 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: adım 16, 3 resimden 2. Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: adım 16, 3 resimden 3.
      • Use a plastic tool to undo all the connections in the motherboard.
      • There are three connections that have to be removed.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S6 Active Front Camera Replacement: adım 17, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement: adım 17, 2 resimden 2.
      • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy S6 Active Front Camera Replacement: adım 18, 1 resimden 1.
      • Remove the motherboard from the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: adım 19, 2 resimden 1. Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: adım 19, 2 resimden 2.
      • The front camera will be attached to the back of the motherboard.
      • Turn the motherboard around and use a plastic tool to undo the connection of the front camera.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S6 Active Front Camera Replacement: adım 20, 1 resimden 1.
      • Use the tweezers to remove the front camera from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucia Valbuena
2.538 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G5
3 Üyeler
51 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 1,101
