Ana içeriğe geç
Samsung Galaxy S6 Active Headphone Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S6 Active Headphone Jack Replacement, SIM Card: adım 1, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement, SIM Card: adım 1, 2 resimden 2.
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Headphone Jack Replacement, Display Assembly: adım 3, 3 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement, Display Assembly: adım 3, 3 resimden 2. Samsung Galaxy S6 Active Headphone Jack Replacement, Display Assembly: adım 3, 3 resimden 3.
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 4, 1 resimden 1.
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 5, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 6, 3 resimden 3.
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 7, 1 resimden 1.
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 9, 1 resimden 1.
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 10, 1 resimden 1.
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Headphone Jack Replacement, Battery: adım 11, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement, Battery: adım 11, 2 resimden 2.
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 12, 1 resimden 1.
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 13, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 13, 2 resimden 2.
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 14, 1 resimden 1.
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 15, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 15, 2 resimden 2.
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active Headphone Jack Replacement, Motherboard: adım 16, 3 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement, Motherboard: adım 16, 3 resimden 2. Samsung Galaxy S6 Active Headphone Jack Replacement, Motherboard: adım 16, 3 resimden 3.
    • Use a plastic tool to undo all the connections in the motherboard.
    • There are three connections that have to be removed.
  17. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 17, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 17, 2 resimden 2.
    • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
  18. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 18, 1 resimden 1.
    • Remove the motherboard from the rear case.
  19. Samsung Galaxy S6 Active Headphone Jack Replacement, Headphone Jack: adım 19, 2 resimden 1. Samsung Galaxy S6 Active Headphone Jack Replacement, Headphone Jack: adım 19, 2 resimden 2.
    • Insert a spudger at the bottom, between the headphone jack connection and the rear case, to loosen the headphone jack.
    • Be sure to pry the headphone jack connection carefully because it is glued to the rear case.
  20. Samsung Galaxy S6 Active Headphone Jack Replacement: adım 20, 1 resimden 1.
    • Use a plastic opening tool to pry the headphone jack up, and remove the headphone jack from the rear case.
Sonuç
Henry Salinas
181 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Harley Fall 2019 IUPUI, Team S2-G6, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S2G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 525
