Ana içeriğe geç
Samsung Galaxy S6 Camera Lens Glass Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: adım 1, 3 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: adım 1, 3 resimden 2. Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: adım 1, 3 resimden 3.
    • Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 2, 1 resimden 1.
    • Please be careful when remove the back cover! It's just a little weak.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 3, 3 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 3, 3 resimden 2. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers.
    • At last, push the camera lens glass by your finger or with a spudger and remove it finally.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 4, 3 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 4, 3 resimden 2. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 4, 3 resimden 3.
    • Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 5, 2 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 5, 2 resimden 2.
    • Peel off the bottom film and we can stick the new camera lens assembly back.
    • And one tips: you will need a piece of new back cover sticker because the old one maybe can't be used any more.
    • That's the guide to replace S6 camera glass and camera ring together.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 6, 1 resimden 1.
    • If your S6 camera lens was broken heavily, just remove it directly but very carefully. Don't hurt the camera or scratch the metal ring.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 7, 3 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 7, 3 resimden 2. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 7, 3 resimden 3.
    • Place the sticker on the camera ring at first.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 8, 2 resimden 1. Samsung Galaxy S6 Camera Lens Glass Replacement: adım 8, 2 resimden 2.
    • And then stick on the new camera glass and done the replacement.
    • That's the guide for replace S6 camera glass only.
    FixBot'a Sor
    Yorum Ekle
Sonuç
54 farklı kişi bu kılavuzu tamamladı.
Sophia
43.911 İtibar
62 adet Kılavuz yazıldı
27Kılavuz Yorumları
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Alex Sangue - Yanıt Paylaş
Yes, that is possible!
Robin - Yanıt Paylaş
I am wondering the same thing. I believe it would work. Don't see the need in pulling the back cover to replace a piece of exposed glass.
4freese - Yanıt Paylaş
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
vicbliz - Yanıt Paylaş
The guide for replacing a heavily broken camera lens is starting from step 6.
tkuilman1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 40
Son 30 gün: 184
Her zaman: 200,152
