Giriş
This guide demonstrates the necessary procedure to replace a defective battery in a Samsung Galaxy S6 Edge.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Neye ihtiyacın var
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Insert an opening pick underneath the battery and slide it across to break up the adhesive underneath.
Twist the opening pick to fully dislodge the battery and remove it.
Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Lay the replacement battery in place, but do not apply adhesive yet. Resume re-assembly until the motherboard is in place (STEP 18).
Apply new pre-cut adhesive or double-sided tape onto the phone frame, around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
Temporarily connect the battery connector to the motherboard to ensure proper battery alignment.
Press the battery firmly into place for 5-10 seconds. Disconnect the battery and resume re-assembly.
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
After completing this guide, calibrate your newly-installed battery.
96 farklı kişi bu kılavuzu tamamladı.
11 Yorum
Interesting but so difficult not worth doing! My A G S6 edge battery expanded in the night and pushed of the back. Fortunately I was awake and saw it happen.
My advice is not use Samsung phones too dangerous!
Any Lion bat is dangerous !! - basic elements and battery assembly are what must be of quality. Too much shi… fake “original” stuff is going around !!
We can do it very easy.
Good guide, but with one minor correction - the SIM card slot is on the volume button side of the phone’s upper edge, not the power button side. An important distinction, considering the potential damage one could do if they stick the pick in the wrong hole.
