Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Telefonun başlatma düğmesi tarafında bulunan SIM kart yerindeki deliğe, bir adet ataş ya da SIM çıkarma aleti yerleştirin.
SIM kart tepsisini çıkarmak için bastırın.
SIM kart tepsisini telefondan ayırın.
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
iOpener'ı panelin üzerine koyun ve cam köşelerinin etrafındaki yapıştırıcıyı gevşetmesi için yaklaşık 60 saniye boyunca bekletin.
Kalan alanı da ısıtması için, iOpener'ı o tarafa kaydırın ve yine bir 60 saniye kadar bekleyin.
Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Disconnect the home button ribbon cable from the motherboard.
Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
Disconnect the earpiece ribbon cable from the motherboard.
Grip the motherboard on both edges toward the top of the device.
Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
Disconnect the daughterboard ribbon cable from the underside of the motherboard.
Lift the earpiece assembly board from its routing channel above the earpiece speaker.
Remove the EMI shield that covers the proximity and gesture sensors.
Pull the earpiece speaker assembly out of the phone, taking care not to strain any cables.
4 farklı kişi bu kılavuzu tamamladı.
