Ana içeriğe geç
Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 3.
    • Peel the clear film off of the adhesive packaging.
  2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 2, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 2, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 2, 3 resimden 3.
    • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
    • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
    • Lay the adhesive on top of the glass.
  3. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 3, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 3, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 3, 3 resimden 3.
    • Run your fingers over the tape to firmly attach it to the glass.
  4. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 4, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 4, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 4, 3 resimden 3.
    • Peel back the outer layer of green film.
  5. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 5, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 5, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 5, 3 resimden 3.
    • Peel back the inner film layer.
  6. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 6, 3 resimden 3.
    • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
    • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  7. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 7, 2 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 7, 2 resimden 2.
    • Use a pair of tweezers to remove any adhesive still on the midframe.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  8. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 8, 3 resimden 3.
    • Align the top of the rear glass with the top of the phone.
    • Press the top edge of the glass into the midframe so that there's no gap at the top.
  9. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 9, 3 resimden 1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 9, 3 resimden 2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: adım 9, 3 resimden 3.
    • Lower the rest of the rear panel and press it firmly into the midframe.
Bitiş Çizgisi
81 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.602 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
3 Yorum
Where do you by the adhesive strip for the repair
Nico Velasquez - Yanıt
There are a lot of places like replacebase
Allspares,and a lot other but usually the back glass comes with the adhesive on
Alkinos vasiliou -
How strong is the s6 edge plus rear glass are they known to break easy.
Aaron c - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 33,944
