Ana içeriğe geç
Samsung Galaxy S6 Rear Glass Adhesive Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: adım 1, 3 resimden 3.
    • Peel the clear film off of the adhesive packaging.
  2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 2, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 2, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 2, 3 resimden 3.
    • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
    • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
    • Lay the adhesive on top of the glass.
  3. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 3, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 3, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 3, 3 resimden 3.
    • Run your fingers over the tape to firmly attach it to the glass.
  4. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 4, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 4, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 4, 3 resimden 3.
    • Peel back the outer layer of green film.
  5. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 5, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 5, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 5, 3 resimden 3.
    • Peel back the inner film layer.
  6. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 6, 3 resimden 3.
    • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
    • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  7. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 7, 2 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove any adhesive still on the midframe.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  8. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 8, 3 resimden 3.
    • Align the top of the rear glass with the top of the phone.
    • Press the top edge of the glass into the midframe so that there's no gap at the top.
  9. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 9, 3 resimden 1. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 9, 3 resimden 2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: adım 9, 3 resimden 3.
    • Lower the rest of the rear panel and press it firmly into the midframe.
Bitiş Çizgisi
141 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
228.383 İtibar
168 adet Kılavuz yazıldı
8Kılavuz Yorumları
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
Rob Crawford - Yanıt
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
shabria jones - Yanıt
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
Richard Meyers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 168
Her zaman: 94,358
