Ana içeriğe geç
Samsung Galaxy S7 Active Disassembly
Neye ihtiyacın var
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: adım 1, 1 resimden 1.
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: adım 2, 1 resimden 1.
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: adım 3, 2 resimden 1. Samsung Galaxy S7 Active Disassembly: adım 3, 2 resimden 2.
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: adım 4, 1 resimden 1.
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chengbin Owen Kuang
207 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G1
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 4,328
