Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will shows you how to disassemble the screen of Samsung Galaxy S7 Active.
  1. Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Wedge the metal spudger in between the screen and the frame to begin separating them.
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Slide the metal spudger around the phone at least once. It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Lift the screen up with your hands.
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chengbin Owen Kuang
183 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G1
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 41
Her zaman: 3,327
