Ana içeriğe geç
Samsung Galaxy S7 Active Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S7 Active Motherboard Replacement, Samsung Galaxy S7 Active Disassembly: adım 1, 1 resimden 1.
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Motherboard Replacement: adım 2, 1 resimden 1.
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy S7 Active Motherboard Replacement: adım 3, 2 resimden 2.
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Motherboard Replacement, Battery: adım 5, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Motherboard Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Motherboard Replacement: adım 9, 1 resimden 1.
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Motherboard Replacement: adım 10, 1 resimden 1.
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Motherboard Replacement: adım 11, 3 resimden 1. Samsung Galaxy S7 Active Motherboard Replacement: adım 11, 3 resimden 2. Samsung Galaxy S7 Active Motherboard Replacement: adım 11, 3 resimden 3.
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Motherboard Replacement: adım 12, 2 resimden 1. Samsung Galaxy S7 Active Motherboard Replacement: adım 12, 2 resimden 2.
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
  13. Samsung Galaxy S7 Active Motherboard Replacement, Rear Camera: adım 13, 1 resimden 1.
    • Use tweezers to disconnect the front camera from the battery.
    • The connector should unsnap similar to a lego piece.
  14. Samsung Galaxy S7 Active Motherboard Replacement, Motherboard: adım 14, 1 resimden 1.
    • Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
  15. Samsung Galaxy S7 Active Motherboard Replacement: adım 15, 2 resimden 1. Samsung Galaxy S7 Active Motherboard Replacement: adım 15, 2 resimden 2.
    • Use tweezers to remove the proximity sensor.
    • Set this aside for now.
  16. Samsung Galaxy S7 Active Motherboard Replacement: adım 16, 1 resimden 1.
    • Use tweezers to disconnect the front mic and the two cables that have been marked in the photo.
  17. Samsung Galaxy S7 Active Motherboard Replacement: adım 17, 1 resimden 1.
    • Use your hands and a metal spudger to lift the motherboard out of the phone.
    • Be gentle, as there is still a connection on the underside of the motherboard.
    • Use a metal spudger to remove this connection.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joe De Leone
310 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G1
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 5,448
